RE: Capiche 140 EX and IC version
The WestonUK ProFlex system will be perfect for this set up. Rubber seals remove the problem of manifolds cracking, and the whole lot will fit in the cowl with just 2 smart polished outlet pipes poking out the bottom.
why ruin the lines of the bottom of the model with a long pipe? You don't get any power benefits (or need any!).
