RCU Forums - View Single Post - 1/5 scale K2 black panther tank
Thread
03-19-2023, 02:45 PM
29
PE YOUNG
Episode 05: The continuing production of bogie wheels
This week, the shape of the bogie wheel has been completed, it has been trimmed, and the production of the bearing insertion type connection joint has been completed.
Regards,
Young
You Tube
Bogie Wheel Work Continues Last Week
Install spokes on the viewing wheel
Spoke operation completed
Create detailed parts with 3D printers
Identical drive wheel cover
Flanges to secure the same drive wheel cover
Remove the burrs on the rear of the bogie wheel with a hand grater.
Finish with a flat grinder
The sharp edges go smoothly, too.
Completing the grinder operation
Stand by for next action
Connecting joint lathe processing
Smaller hole than bearing inner diameter
Hole work completed
Hole operation for bearing fixing
External diameter machining of joint to fit the internal diameter of the bogie wheel
Joint shape machining progress
Shelf machine capacity is small, working repeatedly several times
Joint shape machining completed
temporary assembly
Joint connection with two bogie wheels, bearing assembly example when installing
Check the clearance of the center guard of the track.
Prepare the flanges for hole work to match the bogie wheels.
Continued in the next episode
Reply
Like
tankme
(03-19-2023)
PE YOUNG
View Public Profile
Send a private message to PE YOUNG
Find More Posts by PE YOUNG
View iTrader Profile
