RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 03-26-2023 | 06:26 PM
  #1605
Raleighcopter's Avatar
Raleighcopter
Originally Posted by Rcplanedan
this could be interesting,
Well on the ft160 i have grinded the slot for the low end of the throttle as you showed me bert..so there would be no side movement of the throttle barrel until near half throttle roughly..basically a set mixture to a degree..
When i ran the engine for awhile..yes i noticed the left cylinder (from behind engine)being rich on idle and 1/4 throttle, probably up to half throttle, it would be noticeably richer than the right cylinder..
when above 1/2 throttle it runs rather even and clean on both cylinders..
could it be something to do with offset cylinders and variations in each intake pipe that causes the fight for even vacuum on each side..
My os ft120-ii with airbleed carb doesn't have a barrel that moves sideways and the cylinders run basically the same. There's probably no difference from front cylinder to back because the fuel doesn't enter the cylinders through the crankcase. I don't believe the cylinder offset makes any difference.
