RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 03-29-2023 | 07:29 AM
  #1618
1967brutus
Originally Posted by Cat 1
I tend to agree with this idle analogy Bert... When flying nitro I always end up with an idle you have to baby a bit on the ground - makes for a nice low approach idle if needed. I put it to the loading of static vs Being "driven " by airflow but maybe its not that simple.. An off idle stumble on the ground often disappears in the air.. I do love the sound of a sub normal idle on the ground but would trade that anyway for a clean power band from 1/3 to WOT...
True... as long as the engine does not fail me in the air, I do not really care how it runs on the ground, and by now, I think I have a fair feeling of what an engine that does a good job in the air sounds like while on the ground.
Take a look at this unit - Do you suppose the carb arrangement is to promote cam lubrication or something more? Could distrubute the intake charge to each side if the cam unit was a hollow shaft.
My gutfeeling is that it was intended for cam lubrication, but it could very well be of influence on the mixture distribution as well.
But it depends on how the engine was intended to be mounted, since twins usually have an "up" and a "down"...
