Originally Posted by
Colt4570
Thanks Jason!
Just want to reiterate to everyone,
(Please check the 8 wing tube mount screws in your P-47's). I was able to remove everyone of these screws with finger pressure and the "long end" of an allen wrench. Even if you don't use longer screws with washers and nylocs, at least tighten them with some Loctite. I don't want to see anyone have an issue in the air.
Darrin
This is the fix on the front set of screws.
Thanks Darrin, I will absolutely check out all of the wing tubes!
