Originally Posted by
PE YOUNG
The tank manufacturer decided to manufacture and install the caterpillar of the 2023 1/5 scale Black Panther tank (project name: ic2504) by casting method. The optimal method is to increase production efficiency and reduce the number of iterations.
The shape of the track is somewhat different from the actual one, but it is strong and has increased assembly efficiency.
The production is outsourced processing, and the outsourced production has been requested today.
Regards,
Young
Upper shape of caterpillar
the lower appearance of the caterpillar
A few days ago, a sample of a track made by outsourcing arrived and will be inspected
The sample of the casting track by outsourcing arrived the other day.
The connection is more natural and powerful
Check by hanging it on the sprocket that was made last time
Tightly operated to show less track deviations
The material is bolt steel
It's harder than normal casting
Its surface is grayed out by working with Sendblaster
Make holes and tap screws manually.
