RCU Forums - View Single Post - ECU Battery for other things
Old 04-19-2023 | 04:22 PM
jvaliensi
Turbines draw a lot of energy on start up, after that, they likely draw less than a single servo.
With my FW Avanti X45 foam conversion, I use a single 4000MAH Samsung 40T 2S battery. At start up with the battery at 8V, the current draw will pull the battery down to 7V. But once the turbine is running the voltage goes back to 8V.
Canadian Man (04-20-2023)
