Originally Posted by
grolleman
Had a 2 position switch mounted for the turbine for switching off.
Is this possible?
I use a two position safety switch to change between shutdown and idle position. Done via servo cutoff.
I still use the throttle stick to start the turbine. Don’t need to use the digital trim at all
