Negative on the vise, you can easily distort the case. Glow plugs are 1.5v, fuel should be 80% methanol and 20% oil. Most common oil package for that engine would be 15% synthetic with 5% castor. You need the correct oils that mix with methanol. Adding some nitromethane will increase power somewhat but max would be 15%.
