I ask a mechanic with lath to do the pin at 10 degrees (don't bend as you will have a poor cean angle). I cut the gear at 10 degrees too. For the front, I used the original but it is also crap, I will switch for electron or other good brands , should not be an issue for the front. Only point is how to attach the doors to the leg...but sure we will find a solution
