Originally Posted by
Dave Wilshere
If the channel is default 100-100 then that’s all it needs.
You have definitely set the correct channel for the FM switch in the mapping?
I think it is correct. I will check. It is for sure 100-100 in end points. I will double check on the mapping. I loved the old set up in the Powerbox Mercury and Royal! Why did they change it : . (
