RCU Forums - View Single Post - Help with Powerbox Mercury SR2
Old 05-01-2023 | 10:41 AM
kevinthoele
Originally Posted by Len Todd
What model PBox do you have?
On your transmitter's monitor screen does the designated channel that you chose show the movement of the switch positions when you flip the switch?
Did you program the PBox to tell it what channel are you using to switch PBox's Flight Modes?
When you are programming the PBox gains, and you flip the transmitter's swtich, does the PBox show you that it has changed flight modes?
It sounds like you have not designated the PBox Flight Mode switch in the PBox.
When you do initial set up for gyro you move plane up down left right for oriantation and hit three position switch. I do not know how to tell if it takes input on SR2 other than looking at each surface and it list 10 as channel which I cannot manually enter because there if not output mapping for that
