RCU Forums - View Single Post - Sterling Olympic Challenger
Old 05-02-2023 | 08:27 AM
  #31
plumberdeluxe's Avatar
plumberdeluxe
My Feedback: (209)
Ailerons are hinged and installed and wing is mounted so I will be using the supplied wing bolts and hardwood blocks, was not sure if I was going to change out that hardware or not. Getting closer to getting a start
ing cg and overall weight. May have to build in a small weight in the aft fuse in order to balance it correctly. I did go with the 4 star style aileron set up.
All up weight so far is 2 pounds 5 oz. I may not make the 4 pounds goal. I still have radio gear and covering to go and have 1 pound 11 oz. to spare..
