Originally Posted by
aaronforth
I need help programming the sequencer to pulse a smoke pump using a 3 position switch.
I can get the sequencer to loop and activate on position 3 on a switch, but having difficulty setting position 2 for a set rate, and position 1 as off
I tried using the mixer, but you can only mix a function...
Cant use servo cut because the servo # is not avaliable when used by the sequencer.
What am I missing ?
Have you tried using 3 seperate functions?
Chris
