Originally Posted by
aaronforth
You mean function for smoke off, smoke on, smoke pulse?
Same swith and servo for all 3 ?
Problem is once a servo is assigned to a function its no longer available for another function
Yes, thats what i was thinking
You mentioned once a servo is assigned a function it can no longer be assigned another function.
This is not true. Example. Function called ailerons. Then another function called crow, then another function called flaps will all drive the same servo
Chris
