RCU Forums - View Single Post - Powerbox Core radio and set up thread.
Old 05-14-2023 | 09:32 AM
  #1720
RCFlyerDan's Avatar
RCFlyerDan
My Feedback: (54)
Originally Posted by aaronforth
I need help programming the sequencer to pulse a smoke pump using a 3 position switch.
I can get the sequencer to loop and activate on position 3 on a switch, but having difficulty setting position 2 for a set rate, and position 1 as off
I tried using the mixer, but you can only mix a function...
Cant use servo cut because the servo # is not avaliable when used by the sequencer.
What am I missing ?
I read back to this post. I understand that you can get it to pulse, just not steady. I also just skimmed the manual. I don’t know how to do it, but it seems to me that you would create a virtual switch. Rather then Function or Mixes. Virtual switches can be set up so that, exp: IF this switch is On and this other switch is On, then the virtual switch will work. Or one On, and one Off, then the virtual switch doesn’t work. Or if the first switch is Off, and the second switch is On, the virtual switch still won’t work. But it seems to me that something could be set up there.
I LOVE Functions, because everything, including any mixes can be accomplished there. But I can’t think of a way to make it work in Function. Seems like a buddy of mine said he created a virtual switch on his jet. The pulsating smoke is very cool.
Maybe someone knows more about Virtual Switches. Just my thoughts.
