RCU Forums - View Single Post - Powerbox Core radio and set up thread.
Old 05-18-2023 | 12:56 AM
  #1733
Scott Baker
Has anyone set up a Xicoy telemetry X adapter on the core/atom?
I can't seem to get it to work, trying on 2 different jets. (Xicoy 180, Munts 210)
On the Xicoy telemetry adapter go into advanced settings and change from jeti to powerbox, set fuel tank capacity etc... done
Setup
Powerbox Atom with a Pioneer and 2x 26D PBR receivers and an iSat iGyro sensor.
The iSat gyro plugs into the Pioneer in the center port on the power side labeled FAST Track
The 26D receivers plug into the RX1 and RX2 ports using the P2Bus ports
Using a Y-Harness, disconnect RX1 at the receiver end and connect the Y so that the male coming from the Pioneer is plugged into a female on the Y, the male coming from the adapter is plugged into the other female on the Y, and the male from the Y plugged into the P2Bus port on the receiver.
Power up and add a telemetry widget for RX1 status.
Set the DATA OUT to P2Bus Out, also tried all the other settings i.e FastTrack
S.BUS
SRXL-16
PWM
Bring up your RX1 widget and click RESCAN SENSORS and nothing....
