RCU Forums - View Single Post - Powerbox Core radio and set up thread.
Old 05-18-2023 | 03:32 AM
  #1734
icicles
Originally Posted by Scott Baker
Has anyone set up a Xicoy telemetry X adapter on the core/atom?
I can't seem to get it to work, trying on 2 different jets. (Xicoy 180, Munts 210)
On the Xicoy telemetry adapter go into advanced settings and change from jeti to powerbox, set fuel tank capacity etc... done
Setup
Powerbox Atom with a Pioneer and 2x 26D PBR receivers and an iSat iGyro sensor.
The iSat gyro plugs into the Pioneer in the center port on the power side labeled FAST Track
The 26D receivers plug into the RX1 and RX2 ports using the P2Bus ports
Using a Y-Harness, disconnect RX1 at the receiver end and connect the Y so that the male coming from the Pioneer is plugged into a female on the Y, the male coming from the adapter is plugged into the other female on the Y, and the male from the Y plugged into the P2Bus port on the receiver.
Power up and add a telemetry widget for RX1 status.
Set the DATA OUT to P2Bus Out, also tried all the other settings i.e FastTrack
S.BUS
SRXL-16
PWM
Bring up your RX1 widget and click RESCAN SENSORS and nothing....
Yes, did basically the same setup this afternoon. Had problems also
My setup 2 x 26D receivers. Isat, Pioneer GPS !!!
RX1 and RX2 out of the Pioneer go into the 26D's P2Bus ports on each receiver
GPS111 and Isat went into the Fastrack port on the Pioneer, y lead
Initially i configured the Fast track port on receiver 1 to a P2Bus and connected the Xicoy telemetry here. It doesn't work (So rx now has two P2Bus ports)
You have to connect the main P2Bus port out of Reciever into a Y lead. Then one end goes to your Pioneer RX1 port and the other to your Xicoy telemetry adaptor
Researching i found that when you reconfigure the fast track port on the receiver to another P2Bus it doesn't actually have bi-directional communication. So not a true SBus 2
Hope this makes sense
Chris
