Originally Posted by
oachidori
.... Probably i may wrong but did you use a heatshield instead of aluminum foil for a Eurofighter conversion?
Yes I used the painted on heat shield and not the aluminum tape. The tape is very heavy and sometimes does not stick well on curved parts. Most of the time in my experience it is not needed if there is plenty of cooling air and a double wall pipe.
