RCU Forums - View Single Post - DLE 20 engine
Thread: DLE 20 engine
Old 06-01-2023 | 06:56 AM
kmeyers's Avatar
kmeyers
Originally Posted by rwahl
DLE 20 engine only quits in flight in less than 2 min., will run 5 min. on ground no problems. pick up plane ad move it around with motor running at 3/4 throt. and it works fine.
rwahl,
Join date 2004, yet this post lacks what I would call minimum required information. OK Sooooo....
Like the following:
your level of gasoline 2 stroke tuning, beginner, expert? (or did someone else tune your engine)
what prop are you using?
what fuel oil ratio are you using?
how is the engine mounted and cowled? ( a picture would be best)
what are your needle settings?
what is your fuel tank setup?
Answering these questions would help in a solution from this community.
Respectfully kmeyers
