RCU Forums - View Single Post - Problems with my force 18 engine
Old 06-10-2023 | 06:29 AM
2W0EPI
Originally Posted by Petrollhead
I noticed that the pullstart is very hard to pull when the glow plug was in. After I took the glow plug off the pullstart would pull, but when I put the glow plug back on it was hard. Any idea what the problem could be?
It could be that your engine is flooded or suffering from hydraulic lock, this is when the cylinder is full of fuel making it very difficult or impossible to turn over, remove your glow plug and then turn it over rapidly and see if any fuel is squirting out of the cylinder head and if there is then you need to turn your engine over rapidly to flush out the fuel trapped in the cylinder.
In future, don't stop your engine using your tx controller, if you want to finish running your engine, pinch the fuel line with your fingers and let the engine die through fuel starvation.
