Engine compartment is fuel proofed and engine installed, now it is time to place radio gear in front and see if there is a need to add lead to the front balsa block. Last one I did needed some nose weight so I will assume this one will too. Once c/g is established I can finish covering the bottom and glue the nose block on…….
