RCU Forums - View Single Post - DOES ANYONE KNOW IF.......
Old 11-14-2003 | 04:10 PM
Deandome's Avatar
Deandome
Default RE: DOES ANYONE KNOW IF.......
The reason buggies are thought of as being more reliable & sturdy is because
A) They are LIGHT, so when they crash & land jumps, there isn't a whole lotta force at work
B) They are not designed for, nor often used for, bashing on unprepared surfaces. They are TRACK machines!!!! Exposed (thin!) shock towers, spindly a-arms etc are GREAT for getting the best lap times, but they'd be chewed up in the real world!!
And as there'd be no reason to put on MT tires & wheels for track use, I have to think you want to use it in the real world (fields, construction sites, yards, asphalt, etc.).
NOW YOU'D HAVE A WEAK MONSTER TRUCK, not a rugged buggy!
The weight difference between the wheel setups would be HUGE, and a buggy's drives & suspension would have to be beefed up a LOT.
If you want a "cross trainer", I think you'd be better off going the OTHER way. Get a MAXX or some other MT with a lot of suspension adjustments. Lower the ride as far as possible, work on some BUGGY wheels & tires, and you'd have a decent quasi-buggy. And the Maxx would shine here, as it's already nimbler & quicker than other MTs. Cut the tire/wheel weight in half & you'd get some pretty scary performance!
Dean
