Originally Posted by
Mach1
Is there a trick to easily putting the canopy/ top cover on the 2m and larger Rebels? I have the Hot and it can be difficult but my new 2m seems almost a struggle!
What am I doing wrong? !!
Take a scuff board ( ladies nail file) and sand a slight bevel onto the lowest edge of the hooks. This helps lead then into the slots.
Work particularly on the end tip, lowest point, thinning this like a trailing edge.
My Hot I can put on one handed, the larger 2m has more flex so it needs two hands, but this will make a huge difference.
You can also make the fuselage slots have a very slight lead in by removing the sharp edges either side.
