RE: What Sort of Blade?
After you have ironed a pattern on to the glass and are applying it to the plane, do you do anything to keep the pieces together? I mean, wouldn't the edges come apart when heat is applied to the covering? Do you add trim solvent while the 'cote is still on the glass?
