Originally Posted by
LLRCFlyer
Welcome back to the hobby. I have used many old APC propellers and age does not seen to affect them if they were stored indoors at normal temperatures and away from sunlight. Just check them for balance, cracks or other mechanical damage. As for the fuel, that is a "maybe". You did not state how old the fuel is and whether or not it was ever opened. Glow fuel can last for many years if it is completely sealed and stored at room temperature in a dark place. However, the slightest compromise of the seal can allow moisture to be absorbed into the methanol in the fuel, or allow the nitromethane and methanol to evaporate. I have used tightly sealed (previously unopened) glow fuel that was over 10 years old and it still worked fine. I have also seen fuel less than a year old that was useless due to absorbed moisture and contents evaporation. If you stored the fuel in a jug with a cap having a fuel dispensing hose stuck in the top, then the answer is almost certainly spoiled fuel, especially if it was stored in non-climate controlled space. Store it in a barn and the daily temperature variations will pressurize and depressurized the container, causing moisture laden air to be sucked into and forced out of the jug, causing moisture contamination. Bad fuel can cause poor idle, loss of top end power and flameouts when the glow plug is disconnected. If it is less than 10 years old and never opened, then it is probably worth giving it a try, especially considering that fuel currently goes for $25 to $35 per gallon depending on location, shipping costs and nitro content. The only way to know is to try it.
Thanks. The fuel is in a sealed jug and the color looks good. I've had it in my workshop, which is part of the house, all these years. Not so with the half full jug thats on my flight box. It is a really nasty looking dark color. I'll throw out the nasty stuff and give the fuel in the sealed jug a try at home.
The props are brand new and have also been in the shop. I'll check them over and replace the one that's on the plane.
