HAve what I hope is a simple question. A friend ought a new Atom with a Pioneer and iGryo Sat and asked me to help him set it up. Getting the iGyro working properly has us pretty frustrates at this point. We've gone into the Pioneer menu and selected Aileron A, B, etc and for starters simply left them at defaults. For Input Mapping we selected Aileron A = channel 1, B= Channel 2, Elevator A= channel 3, B=Channel 4 Rudder = Channel 5. These are all correct and all control surfaces move normally and in th correct direction. In Gyro position setup when in response to Tail Up we lift the tail and one Elevator goes up the other down (Elevator A/Ch 3 is reversed). The iGyro manual keeps referring to set gyro outputs but we can't find any such menu and I assume that would all be where we correct the left elevator moving in the wrong direction in response to the til being lifted. Also, after completing gyro position test and stick limits then the gyro makes no corrections on any axis, regardless whether the gyro gain switch is set to off, A or B... Im sure we're missing something simple / obvious but if someone could give up a hint as to what we're doing wrong I think we can figure it out from there. And yes IU have read the manual (which was pretty worthless) several times..
Wayne
