RCU Forums - View Single Post - Powerbox Core radio and set up thread.
Old 07-27-2023 | 10:48 AM
  #1763
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by David Gladwin
I THINK your problem is using two channels for elevators and reversing one of the channels for one elevator. If you drive BOTH elevators from the same channel and then, on the SERVO page, reverse the required elevator servo you MAY find the problem solved.
This is only a suggestion as I do not have a Pioneer, my standard is the Competition SR 2, but give it a try !
Thanks for the reply. I did reverse the elevator servo (channel 3) in the servo page and both servos move correctly when I move the transmitter sticks. However in the Gyro Position test, when it say to lift the tail, the left elevator (channel 3 which is reversed) gos down and the right elevator half (channel 4, normal) goes up, so the gyro is correcting in the wrong direction and I'm wondering how to fix that..
Also, even though the servo page show Elavator L for channel 3 and Elevator R for channel 4, if I look in the servo monitor it show Aileron L, Aileron R, Elevator, Elevator, Rudder L.. I'm not sure If I assign something wrong but don't understand why the servo assignment page and the servo monitor page would show different names (Elevator, Elevator instead of Elevator L and Elevator R)...
We took a break for lunch but were going to get back to trying to figure this out now so any fritter suggestions would be appreciated.
Wayne
