Originally Posted by
FlyJ
It's not a problem to have the elevators move in different directions during the teach portion. Once you go through the mounting position teach and the end points teach, you'll see the elevators move correctly when testing the gyro.
You mentioned that you can't see the elevators moving after teaching them. My recommendation is to set your gain channel to +100, 0, -100, then set the gains on the gyro to 100% AND turn on attitude assist. This will allow you to move the airplane around and check if the movements are correct. Once you confirm everything is moving correctly, then back off the gains and remove attitude assist where necessary.
Ok, I performed the Mounting position which is where the Elevators Moved 1 up / 1 down and then performed the teach function. After that I tried selecting Bank A and Bank B and saw no movement of any controls so I assumed something was wrong. All the other gyros I've used in Normal Mode you could see at least some small movement of the controls as the plane as pitched, yawed or rolled and after carefully checking there definitely was none. We did however have Attitude hold set to off. I'll turn that on, select each Axis (Aileron A, Aileron B, etc and set each gain to 100% and Attitude hold to on and see what happens. Thanks to everyone that's relied with suggestions. It's appreciated..
Wayne
