RCU Forums - View Single Post - Powerbox Core radio and set up thread.
Old 07-27-2023 | 12:50 PM
  #1769
FlyJ
Originally Posted by wfield0455
Ok, I performed the Mounting position which is where the Elevators Moved 1 up / 1 down and then performed the teach function. After that I tried selecting Bank A and Bank B and saw no movement of any controls so I assumed something was wrong. All the other gyros I've used in Normal Mode you could see at least some small movement of the controls as the plane as pitched, yawed or rolled and after carefully checking there definitely was none. We did however have Attitude hold set to off. I'll turn that on, select each Axis (Aileron A, Aileron B, etc and set each gain to 100% and Attitude hold to on and see what happens. Thanks to everyone that's relied with suggestions. It's appreciated..
Wayne
Did you also teach the end points after teaching the mounting position?
