I have some additional questions about test fying the plane and setting the gains in flight. Do you setup up more than one gain control ? For example use the left knob configured for a range of 0 thru +100% and the right knob configured for - thru -100% and set the Ailerons to bank A and all other controls to Bank B and leave Bank B gain very low and increase Bank A (Aileron Gain) until the Ailerons just start to Oscillate and the reduce Bank A until they stop oscillating ? then adjust Bank B until the Elevator (or Rudder) Starts to oscillate and reduce a bit ? Or am I over thinking this and should just stick to a single Gain knob with everything on a single Bank and just increase gain until one of the Axis (Im guessing Aileron) oscillates, reduce until it stops, land and adjust the gain for the Axis that oscillates? Then test fly again and repeat reducing the gain of the Axis that oscillates until I get nicely balanced gains for each axis?
Since I'm very new to the Atom and Power box I'd be happy to get any addition setup suggestions from experienced users..
Thanks for any additional suggestions you may have.
