Originally Posted by
invertmast
before i throw money at it, im going to find a place with more runway… preferably paved… and get the gear issue fixed. I’m also going to move some stuff around to try and remove the ballast weight.
Was the final weight as on scales posted? Over 50 fueled ? Did you do a static thrust test? I know my Skymaster one is pretty heavy wet and really worked to get CG just right. Maybe your CG could be tweaked a bit? Loosing weight always a good idea!!!
