RCU Forums - View Single Post - 3D Printed Painting Problems
Old 08-31-2023 | 09:25 AM
yellowshaker's Avatar
yellowshaker
What are you tinning the tamiya paints with? I recommend the tamiya laquer thinner for those paints. Also I have not had much luck using mr surfacer as a primer.I'd use a normal primer or even try the tamiya paint without primer and see what results it yields. You should have no issue using those paints.
