[QUOTE=model1258;12781864]Do you use the small felt clunk the one carf supplies in your tanks, Dave?[/QUOTE
i actually use a clunk we had made in the U.K., same as CARF one, but bigger hole. If you are careful you can drill out the Tillotson one supplied, do it in steps to 3mm. Then it will work perfectly with the new Brushless pump on the P-130
