That hint with 160 Rxb = 180Rxb sound good.
I have checked the max rpm according datasheet and the 160 has 122000 at 158N, the
180 125000 at 175N.
If these two engines are using the same hardware it should be possible to just change the max rpm in the ECU..
is there a way to do that? (have the V10 ECU)
thank…..would change the rpm to 124000…..
