Sail servo sources
Originally Posted by
AEK42
It seems you need all new electronics. The transmitter (Tx) should not be hot. Servos should hold steady as long as they are powered.
FlySky makes a good, inexpensive set of electronics. Many sailors use the FS-i6 Transmitter. I got mine together with a FS-iA6 Receiver (Rx), at $53. This Rx is a circuit board with cardboard cover. Better Rx is FS-iA6B, $16. I got this from Amazon.
Sail servo could be Hitec HS-765 $39 and Rudder servo Hitec HS-485 $17. These are most popular.
The boat should be great.
My sail servo just died. I see on Amazon a
Hitec HS-765 but it is priced at $54. Where do you see them for $39? What is your source for the Bluebird BMS-630MG servo?
Reason: Additional question
