Well redirecting the oil vapor from the crankcase through the rocker boxes is a damned sight better way than oil migration through the valve guides, and what gets past the cam followers and up the push rod tubes, it works to some extent... rather that, than the os pcv system, or the Moki radial's with their greased cam followers, which is an asinine way to lubricate a valve train.
