Originally Posted by
ECHO24
You don't have to put anyone on the spot. Just say you saw it on a discussion forum and after reading the quoted text it does appear that the FAA overstepped its authority claiming they can bring an RID action against someone without clearly defining what "unable to comply" means, for example, "Exceptions include, 1) A drone pilot does not have the financial means at this time, etc." Or, "Financial ability is not a valid reason for non-compliance." (remember, this is aimed at not just adults). As such, ... [the] enactment is void for vagueness [because] its prohibitions are not clearly defined.
Source for EVERYTHING in quotes above? When you want someone to help, generally best to do the research for them. Tell me exactly where each phrase in quotes came from, and provide link to source document.
ECHO24
(LOL, I forgot you haven't met a regulation you didn't like.)
If you want someone to help, generally doesn't help to level untrue insult when asking.
