RCU Forums - View Single Post - Hyper 7 headplate
Old 10-09-2023 | 12:34 AM
JackHand
If you tell me the diameter of the cylinder, and if possible also the bore (check that they are the same), I can help you find out. The best way to do this is to use a calliper (I use an electric one), which will give you all the necessary information as well as the dimensions or other data needed.
