I have flown them with both a120 and a 140. The 120 is more than adequate if you keep the over all weight down to around 27lbs, which is not hard to do with this jet. I prefer the 140 because I like a little more thrust authority. Landing is about the same with either.
if you are operating from thick grass the 140 might be preferable.
