RCU Forums - View Single Post - Newbie With an issue
Old 11-06-2023 | 01:21 AM
  #35
shadyhazza
Originally Posted by Zool
So i fitted this. and hooked it all up and it fired up fine.
However on acceleration there is this kind of chinking/grinding/metalic clicking noise. it only happens under stop to start initial load then stops once it is moving. at first i thought it was the motor's gear slipping but its not.
I could take a video of it tonight.
Any help would be appreciated.
I'm necroing this thread because i'm just trying to bring a bugsta back to life and I might know what the problem is here.
The center drive dogbone can move forward and backwards, that makes noise that a couple of o-rings in the dogbone cups can fix.
but I discovered that the bearing bracket that slots into the motor mount in this bugsta was missing, meaning the spur has up and down play !! I thought I had the mesh right and all when I destroyed the 2nd pinion, but then i discovered the spur wasn't fastened down.
River Hobby 10200 Bearing Bracket (FTX6262)
If that's missing, you were so close looking at the spur bearing but not quite there. I'm not ready to give up yet since I just got it haha. Maybe its yours
