RCU Forums - View Single Post - CARF Bolt! Build thread
Old 11-06-2023 | 12:20 PM
  #171
RCUser012
Guest
My Feedback: (73)
Originally Posted by vegasking
I don't think I have found a solid CG point on the manual or on this build. Does anyone have a actual measurement from a point to a point where that is? I've been told to make the weight on the nose gear from 1300-1500grams.
the manual states to hang it by the wing bolts and to start with it slightly nose down , and remove some nose weight from there.
you cant really go by weighing the weight in the nose as this will be relative to the percentage weight of the whole plane where your specific one ends up ... I know they wont come in far off from each other , but turbine choice, battery count and spec, smoke, etc will add up ..
