Originally Posted by
J.Paul Saure
Any thiughts about it?
Thanks!
that is not really too much of a problem. you can stuff and glue a plywood shim on one side just to squeeze the pipe down a little more. there really is not much or any sideways load back there as the pipe is held into the aircraft at the front tabs .... and technically , a properly placed turbine, leaves the pipe without even that much thrust load on it either ..
