Interesting project Bert... you could rewrite the sketch so it turns on the solenoid valve on the induction stroke via a small magnet on the side of the cam gear... hall sensor mounted on the cam cover... do away with the 50hz (PWM) modulation, and vary the on-time using (PDM - pulse duration modulation) via a varing delay, vary the on-time via the channel mix curve.
