RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 11-06-2023 | 08:14 PM
  #1991
Raleighcopter's Avatar
Raleighcopter
If the throttle is managed by an onboard governor, there's essentially no throttle position available at the transmitter to slave a mixture curve to. It would require adding a throttle position sensor and moving the mixture curve to the controller and everything that entails. It's a major rewrite of the code and additional hardware (probably a magnet and hall sensor) to read throttle position.
