RCU Forums - View Single Post - Vanessa c.g. Rig: How to.
Old 11-20-2023 | 03:19 AM
  #237
Fulmic
Good Morning to All of You.
I wrote you from Italy and i would like to have a clarification regarding Vanessa System. If i need to balance a glider Gruapner Grob Twin Acro with 4 Mt wing i need to keep in consideration that the horizontal rudder is completly moveble is not as a regular model with a fix and mobile part.
In this case the main condiction is that between the wings and the horizontal rudder i need an angle of 1,5 Degrees.
My question is the follow
To balance the model with Vanessa in principle i need the Horizontal rudder at 0° and on that position a check the CG on the wing.
But in the case of a completly moveble horizontal rudder i need to start from the wing and in this case i need to put the wings at the angle of 1,5° and later on in such position set to 0° the rudder. It is that correct?
