I now offer several upgrades for the TD M60 tanks.
A new drop in ready servo recoil with scale gun barrel kit for the TD M60A1/A3 tank. It includes gun barrel of your choice, M60a1 profile or M60a3 heat shielded, the recoil unit and the servo. Installation is made easy as all the measuring and alignment is pre set up for you all you need to do is a slight modification to your tank that my video will walk you through. The A3 barrel is pictured below.
The drop in replacement kit retails for $90
Note this is not applicable for the IDF M60.
Both gun barrels are available separately as well at $45ea
The universal recoil unit fits henglong and other tanks and is $37
I also offer a pair of ball bearings for the main gun pivots if your tank did not have them included as seen in the photo below.
Both of my tanks were missing these pivot bushings and without them the gun slops side to side and can fall off the elevation unit arm when you hit a hard bump. My pair of ball bearings takes the place of the nylon bushings if you have them or if you don’t, and creates a nice firm installation $8 a pair.
I have a small supply of plastic track for the m60s both the chevron and. Hexagonal pad type since we determined the tanks run better with the plastic track $45 ea
Spot light kit for the M60 $20.
see my website for more info guys.
RC Tank Products
