that's a nice shop table. wish mine was that big. i try not to add up how much money i have in these planes lol it makes me feel better.
make sure to check your nose gear strut spring. i tried to compress the nose strut and using all my force i could maybe just barely get it to compress. took out the spring and the grease they used was more like glue. cleaned out the strut and the spring and put regular grease on. now i can actually get it to compress. still may be too stiff will test it out later.
retract and door programming was very simple. had that done really quick. the gear seem to be very strong. pleased with them so far.
had to cut the cowl significantly to clear the steering servo push rod. didn't mind bc need to cut it for cooling anyway.
picture of the main gear door servo install. in the manual they had the servo rotated 90* from the position mine is in.
