I read about this issue somewhere before I started building, but now I can't find the information. What is the best way to relieve the bottom aileron leading edge and or the wing trailing edge so the ailerons will go down? From the factory, the two bottom edges butt up against each other and because the ailerons are hinged on the top, will only go up, not down.
