Correction
[QUOTE=DaleCS;12790582]Using drawings, I found that the overlapping panel lines are parallel with the trailing edge of the vertical fin (fin, not the rudder!).
After laying out the markings for the vertical overlapping panel lines on the right side of the fuse, it was just off a bit. Rechecked the drawings, got out my drawing triangle tools and yes, I was wrong. The trailing vertical fin edge is NOT parallel to these panel lines. Close, but not close enough.
More checks, and I've settled on using the rear panel of the cockpit. A few lines marked and drawn and it's looking much better. A couple of degrees makes a difference.
